Hi,
As per some recent posts on this forum, we are having a lot of issues with AutoCAD Civil 3D Object Enablers in MicroStation CE and Platform Products, like OpenRoads Designer.
Short of uninstalling it, is there any way to disable or force MicroStation to use its RealDWG default instead of the Autodesk Object Enabler? It is quite an effort to uninstall it on dozens of machines, which also removes the AutoCAD functionality the OE was intended for.
Regards,
Mark
