Dear Sir/Mdm,
I am currently running many commands through a p3d.log script using the command runner window in PLAXIS 3D. However, as I am running over 10 000 command lines, the time required for the file to finish running is quite long. May I know if there is any way for me to speed up the process? Thank you very much!
Dear Wang,
I believe that all the comments from Rushan are very useful so please check them.
In general, we see a performance improvement when the Update visualization during execution is unchecked so that the canvas does not need to be updated each time. However, 10000 commands are quite a lot so you can consider doing some clean up to have only the necessary commands for creating the project. The Expert>Examine command option can assist (as Rushan mentions).
One thing to point out when using a toggle is to remember to remove it afterwards in order to be able to use the software normally again.
