OpenRoads | OpenSite Forum - How To Fix Bowties in OpenRoads Designer Connect Edition
Question
by
Aaron McLean
Rising Star
Created (Edited ) in OpenRoads | OpenSite Forum
Hi,
Does anyone know a quick solution to fix the Bowtie Error that happens around tight corners of a corridor? (image below)
- I know you can delete all the vertices, but it just goes back and re-draws if any edits are done to the corridor.
-I know you use a clipping reference to clip out the bowtie, and then generate new lines manually but that is very tedious.
Looks like Civil 3D solved this in 2018 so surely ORD 2021 must have a solution no??  Civil 3D 2018 New Feature: Clear Corridor Bowties - YouTube
Thanks in advance!
Aaron.
