Licensing, Cloud and Web Services Forum - Failed to install CONNECTION Client with error code 0x80070643. Fatal error during installation.
Question
by
Bentley Communities Legacy Member
Expert
As  I followed the video tutorial on installing staad pro, installation error on connection client keeping me not in progress.
What should I do? Please Help.
10 Replies ( Latest reply by
Hello,
Please upload the CONNECTION Client install .zip file from the Temp (%temp%) folder by following the secure file upload instructions here: https://communities.bentley.com/help/w/be_communities_help/7079/communities-secure-file-upload
Change the name of the .zip to cgrospe.zip before uploading and reply back to this discussion to let me know that it has been uploaded.
I have checked the log. I think it is the first cause of error.?
... "Error 0x80070643: Failed to install MSI package.
Error 0x80070643: Failed to execute MSI package.
Error 0x80070643: Failed to configure per-machine MSI package. ..."
Hello,
Thank you for uploading your logs. I see the following error in the log:
Error 1935. An error occurred during the installation of assembly 'Microsoft.VC80.CRT,type="win32",version="8.0.50727.6195",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="amd64"'. Please refer to Help and Support for more information. HRESULT: 0x80073715.
To resolve that error please follow the steps in this Microsoft solution: https://support.microsoft.com/en-us/help/926804/error-1935-when-you-try-to-install-microsoft-office-2010-or-2007
Hi,
Thanks for the concern.
I already did your instruction and uploaded the log file named as cgrospe.zip.
Thank you.
Hi,
Thank you.
Hello Hawa,
Depending on the version of .NET you have installed you may need to use an updated tool. Try the suggestions here: https://blogs.msdn.microsoft.com/astebner/2008/08/28/net-framework-cleanup-tool-users-guide/
First try the cleanup, then the repair tool if that doesn't fix it.
Hello, can you help me with the same problem too? i've tried the suggestion given by you but still not working. I uploaded the zip file by the name chawa.zip
thank you
Hi,
Can you help me please? I uploaded the file Andrei Pop.zip
I failed to install Bentley view connect Edition with error code 0x80070643.
thank you
Hello,
The logs say you don't have enough disk space:
Error 1307. There is not enough disk space to install this file: C:\WINDOWS\Installer\186128.msi.  Free some disk space and click Retry, or click Cancel to exit.
