Using Openroads Designer:
I've created a ruled boundary, editing the edge triangles has not been an issue. However, the triangles disappear whenever I move/insert vertex on the boundary. I then have to reselect the terrain model to view its properties and turn the triangles or contours back on.
Is there a way to make the calculated features stay on while editing the boundary?
Hi Kevin,
Just give it a Feature Definition that has triangles displayed by default - it reverts back to its default symbology settings on recalculation. Alternatively, you could edit the Element Template settings of your current Feature Definition to have Triangle display turned on as well.
