To Whom May Concern,
Ram Element regarding to the masonry wall module:
Attached Integrated wall design report (TMS 402 - 2008 ASD).
Since the wall is symmetrical, the bearing wall result for Ma of combined axial flexure (P. 6) should be the same for segments with the same thickness, reinforcement, block strength & fill solid with grout (highlighted in similar color).
However, the resulting Ma is difference. Could you please explain why?
Thank you in advance.
Topics: RAM Elements
