OpenRoads | OpenSite Forum - Survey Data import from AutoCAD Topographic Survey drawing into ORD Survey Data
Question
by
Babulal Sahu
Champion
Created in OpenRoads | OpenSite Forum
Hi,
I am having problem in importing any points or 3Dpoly lines from AutoCAD drawing into ORD as Survey Data. We usally get the Survey Data in Autocad drawings formats.
When I am selecting any 3D Poly lines for importing into ORD by selecting Graphics option......There is no process going on.
First I have attached the AutoCAD drawing into ORD. Then used Graphic option to import the CAD data into ORD Survey data, but these is no response in ORD.
I am attching the AutoCAD drawing for reference.  Could anyone describes what is the best workflow to import survey data from AutoCAD drawing into ORD survey Data
Regards
Babulal Sahucommunities.bentley.com/.../TopoSurvey-Data_5F00_Project_2D00_0256.dwg
