RAM | STAAD Forum - Correct method to analysis and design pile raft using staad.pro and staad foundation?
Question
by
Mohamad Adam Azman
Explorer
Dear Sir,
Need your help in clarified my method to analysis pile raft.
I model the pile raft using staad.pro and asign plate with thickness of 1.8m, for foundation, i asign as plate foundation with subgrade modulus of 150kN/m2/m which equal to 1.5kN/m2 of bearing capacity. Then I asign load to it and run for analysis.
With the analysis result I transfer it to staad foundation, i asign mat foundation and add pile to it to find the max reaction of pile and design the mat foundation.
The question is, is this is the correct method or i need to put pin or fixed support instead of plate foundation in the staad model before i transfer it to staad foundation?
Thanks
