I have performed a run using SACS 16.0 and found something weird on pile unity check, which has shown no pile UC value in output listing file.
Is it a bug in this latest version? FYI, the input file is running based on ISO 2020 code. Running the file on older code (ISO 2007) have no issue.
There is no mention of ISO 19902:2020 code check option in the PSI manual in the SACS 16.0 version.
There is a bug with PSI for ISO 19902:2020 code check. The developer is looking at this issue and fix in future release.
