OpenBuildings | Speedikon | Forum - Import Civil 3D Model (dwg/ifc) with Extended Data
Question
by
Bentley Communities Legacy Member
Expert
Created (Edited ) in OpenBuildings | Speedikon | Forum
Hi all,
I trying to import a model authored in Civil 3D that has meta data attached using the Extended Data function as shown below. When I open or import the source DWG or exported .ifc with embedded data none of this pulls through into AECOsim. Does anyone have a solution for this interoperability problem?
