Hevacomp Forum - K VALUE FOR DEFAULT BENDS AND TEES
Question
by
Gyanendra Limbu
Explorer
Created in Hevacomp Forum
Hi
Understood the below links gives K-value for some of the fitting however, it doesn't show the assumed value for different default bends and tees . Please could you be able to post the k vale for the default connection fittings. i want to verify the pressure loss is correct and is inline with CIBSE guide C.
https://communities.bentley.com/products/building/performance/w/building_performance__wiki/17605/pipe-and-duct-fittings-k-values
Many Thanks
Regards
GL
