ProjectWise Announcements Forum - ProjectWise Explorer 2024 is now available
Question
by
Patti McMillan
Rising Star
Created (Edited ) in ProjectWise Announcements Forum
Bentley is excited to announce that ProjectWise Explorer 2024, the main desktop user interface for ProjectWise, is now available in Software Downloads !
What's New in ProjectWise Explorer 2024
ProjectWise Explorer 2024 features several updated capabilities and performance enhancements, including:
CAD Integrations
With this latest release, ProjectWise Explorer now supports the following applications:
    • AutoCAD 2025
    • Civil 3D 2025
    • MicroStation 2024
    • Revit 2025
To align with Autodesk version support, ProjectWise Explorer will no longer support AutoCAD 2021 and earlier versions.
Civil 3D Improvements
ProjectWise Explorer 2024 introduces significant time-saving performance improvements compared to version 3.4 with respect to integrated Civil 3D tasks, such as opening projects, opening the master with an associated project, repairing broken references, and more.
Spatial Scanning Technical Preview
With this release, ProjectWise Explorer re-introduces a feature that adds spatial context to documents and folders in a ProjectWise data source. This feature enables you to scan and extract coordinate system data using the Scan for Spatial tab in Document Properties.
Note: Spatial scanning requires a minimum of ProjectWise Integration Server version 2023.00.00
MicroStation Item Types Technical Preview
This release also supports attribute exchange with item types for title block updates. Only desktop integration workflows support attribute exchange, server-based workflows are not supported with this release. Additionally, only the File>Open command is supported in this technical preview at this time. If you are interested in participating in the technical preview, please contact  Phil Conard, Product Manager II, or for more information, see "Upgrading Tag Set to Item Types" in MicroStation 2024 Help.
Important Note for V8i Application Users
Our focus is to provide innovative, secure technology; therefore, ProjectWise Explorer 2024 will no longer support V8i applications. For more information, see the following Bentley Communities announcements:
Get Started with ProjectWise Explorer 2024
Administrators can install ProjectWise Explorer 2024 by following these steps:
  • Remove old versions of ProjectWise Explorer and ProjectWise Administrator
  • Ensure that you are using the appropriate operating system - Windows 10 x64 and Windows 11 x 64
  • Go to Software Downloads
  • Click Download for either ProjectWise 2024 Client setups or ProjectWise 2024 Admin setups
    Please note, if you are running both ProjectWise Explorer and ProjectWise Administrator on the same machine, they must be the same version.
