Good Day Everyone,
May I ask your help, I'm simulating a model that will cater the existing scenario that works with a hydropneumatic tank. The operational scheme is a submersible pump fills the pressure tank, then feeds to the system.
Data:
Note these are the only data I have.
-1265 gal - tank capacity (1.56m - diameter, 2.5m height)
- NGL -20m, Pumping water level - 180ft
- SP8-15 pump and 0.15MLD Demand
My questions are,
- First, can I simulate this using WaterGEMS Connect Edition? If yes, will I ratio the 1265 tank with 70% Liquid : 30 % Gas?
- What does it mean of Liquid Volume(Inital)? Can I assumed that the initial volume is 50% of the 70% capacity?
- In physical properties, the volume indicated there is the total volume of the tank?
- Tank model calculation: what do you recommend? Constant Area Approach? or Gas Law Model?
- If Constant area - HGL On and Off - the on/off of the pump regarding to the 2.5 height? I mean if I allocate that 2.45 in HGL Off the pump will be off? and viser versa?
- If Gas Law Model, will I indicate other inputs from my data or just the default Variables like Atm pressure head, ratio of loss and Gas law exponent and run the system?
Can I ask some advice or other suggestions to consider for this scenario? Thank You!
God Bless and Best Regards,
Marco
Hello Marco,
communities.bentley.com/.../17625.how-are-surge-tanks-and-hydropneumatic-tanks-used-in-watergems-and-watercad-models
communities.bentley.com/.../3104.modeling-reference-hydropneumatic-tanks
