Hi everyone!!
I have this code , First I promote a point cell feature from a SharedCell , then I´ve triying to read some properties like coordenates, cell name and others, and then add this cell properties to a feature properties. The rare thing is in a machine i have this error (430) but in other no and is the same DGN File, because i am in the prove fase. What is wrong in my code?
I am using Bentley Map SS3.This is the code. Thanks!!!
Set fe = locateOp.GetLocatedFeatures Set ee = ActiveDesignFile.Fence.GetContents With oFeature .AddToTransientAsHilited .ApplyAttributeChanges Do ' -------- Set oCell = ee.Current If oCell.IsSharedCellDefinitionElement Then ShowMessage "This elemen is SharedCellDefinitionElement", "", msdMessageCenterPriorityInfo, True End If If (oCell.IsSharedCellElement) Then If (oCell.AsSharedCellElement.Origin.X = .Geometry.AsSharedCellElement.Origin.X) And (oCell.AsSharedCellElement.Origin.Y = .Geometry.AsSharedCellElement.Origin.Y) Then '---------------------- Dim oCellNombre As String oCellName = oCell.AsSharedCellElement.Name Exit Do End If Else If oCell.IsCellElement Then If (oCell.AsCellElement.Origin.X = .Geometry.AsSharedCellElement.Origin.X) And (oCell.AsCellElement.Origin.Y = .Geometry.AsSharedCellElement.Origin.Y) Then '------ oCellName = oCell.AsCellElement.Name Exit Do End If End If End If ' Is shared cell element Loop While (ee.MoveNext) If .Geometry.Type = msdElementTypeSharedCell Or .Geometry.Type = msdElementTypeCellHeader Then ' --> Both .setProperty "CELLNAME", oCellName .setProperty "COORDX", .Geometry.AsSharedCellElement.Origin.X .setProperty "COORDY", .Geometry.AsSharedCellElement.Origin.Y setProperty = True End If
