New Release – AutoPIPE Vessel 2024 (45.00.00.133) is now Available. The Most Comprehensive Software for Pressure Vessel, Heat Exchanger, Air Cooler, and Tank Design Optimization
Download from Bentley ... click here
Download the ReadMe File... click here
The following outline identifies new features and enhancements in the AutoPIPE Vessel 2024 (45.00.00.133).
- Enhancements
- General
- Model (.emvd) version handling. From now on backward compatibility is assured by having the option to save in an older model version. In this new release, only conversion between version 6 (v45) and 5.2 (v44) is possible, other versions will be added depending on future developments. For older software versions (v43 and before), 5.2 should be chosen. Version 6 is only compatible with v45 software onwards.
- Codes/Standards Update
- ASME 2023 Boiler and Pressure Vessel Code - Section VIII, Div.1 & Div.2 (ONLY calculations update, material update coming soon in next update).
- French Design Code CODAP 2022 update.
- Implementation of NB/T47041 Seismic load, par. 7.5 for vertical vessel on skirt as per Chinese standard.
- EN 1092-1:2018 Flange standard update.
- Interoperability
- Generate DWG drawings without AutoCAD/BricsCAD. Users do not need AutoCAD/BricsCAD license anymore to generate .dwg drawing files.
[Technology Preview]
- General
- Added support for AutoCad 2024 export.
- Option to export to AutoCAD 2017 to 2018 versions discontinued. Export to AutoCAD 2019 versions or newer are only supported.
- Option to export to SolidWorks 2010 through 2017 versions discontinued. Export to SolidWorks 2018 through 2023 versions are only supported.
- Implementation of Chinese saddle standards based on NBT 47065.1-5 2018 (3D MicroStation and 3D IFC).
- User Interface
- Replacing tabbed dialog boxes with wizards for creating new models (Pressure Vessels and Heat Exchangers).
- "File > Open" Dialog updated to allow quick access to example folder, config folder and working directory.
- Defects
NOTE: Problems described below represent specific issues with specific test cases. It is difficult to succinctly describe a problem and how it impacted the specific test case. If you have any questions about the issues discussed in this report, please contact technical support.- Calculation / Report
- #1081749: CODAP - Skirt Junction - Interpretation of gamma angle is incorrect.
- #1083899: Limpet Coil - Di formula printed is incorrect in the report.
- #1110533: Flat Head - CODAP - C3.2.2.5 Exceeded values are not shown in red in the Report.
- #1327109: ASME Half-Pipe Jackets - The maximum permissible pressure must always be calculated with the inside diameter of the inner vessel.
- #1327166: ASME VIII Div.1 - Multiple Openings with self-reinforcing (program could be stuck indefinitely on assumed opening calculation).
- #1327190: Lifting Lug Checking - CoG location issue when the tailing lug is located above the skirt.
- #1332304: Limpet Coil - ASME Div 1 and Div2: scope of application of K should be restricted.
- #1332496: Heat Exchangers - MAP is not calculated nor can be imposed.
- #1340586: EN 13445 16.12.5 Anchoring on conical skirt - Calculation gets stuck (infinite loop).
- #1341878: ASME UW-16(c) - Weld sizes check : MAP condition lead unexpected warning message.
- #1344402: Saddles - "Shell Wall's Thickness" wear plate option does not work and the weight may be incorrect if modified during the optimization process.
- #1378719: Heat Exchanger - Backing flange chamber number is not retrieved.
- #1379386: CODAP Fatigue Analysis - Flange on Nozzle: resistance class and stress index are wrong.
- #1401170: ASME Fatigue Analysis - Equations (3-F.1/6/9/15/18) (Y-value) issue.
- #1233577: Lifting accessories - crash when accessories are outside of the vessel.
- #1377643: Reverse heat exchanger - channel nozzles might be moved onto shell when no location set.
- #999192: Program crashes when a tray is on a flange.
- #641358: EN 13445 - Stiffener material not fully defined leads to crash the calculation.
- #641476: Earthquake (large conical shell) - sum of mass doesn't match the foundation load mass.
- #640836: Lugs on transition head have a Render 3D issue and they are not calculated.
- #1009438: Report - Vessel on Saddles - Add explanation about longitudinal bending moment (Foundation loads).
- #1106375: Report - CODAP - Skirt Junction's geometrical restrictions are not in red when not respected.
- #1327204: Report - Local load due to Legs on conical shell out of scope without warning message.
- #1364940: Report - Summary Of Changes > Body Flange Thickness - value is not rounded.
- #1354715: Report - Clearly mention that only Kloepper or Korbbogen head types are covered by AD B3.
- #1367907: Report - Painting area of stiffeners on conical shell underestimated.
- #1379349: Report - ASME UW-20/A-2 - Tube to Tubesheet joint - incorrect depth of groove weld / fillet weld leg.
- #641278: Report - EN13445 Annex G - to add a warning message about the allowable bolts stresses.
- User Interface / Others
- #1226955: GUI - Fatigue analysis - a negative Pressure is not limited by External Design Pressure.
- #1274334: GUI - Change Nozzle Location - after using a Move option, that option is disabled.
- #1303947: GUI - Project Specifications: some values are not read in the Heat exchanger creation.
- #1356078: GUI - Floating Head Flange - Data is linked to a Body Flange.
- #1382669: GUI - Menu > Execute > "Convert Results as Input data" changes the length of a cylindrical shell when a couple of flange precedes it.
- #1363808: GUI - Crash when "moving to production" AutoCAD cell library.
- #1381500: GUI - Tank - Supported roof - Shape type selection is not saved correctly in EMVD.
- #1374312: GUI - Crash when creating a new Boiler with Smoke Tubes (Furnace Material tab).
- #1406423: GUI - Corrupted tee components that are not visible cannot be removed.
- #1242268: MDM - Modulus of Elasticity units in printed html are MPa instead of GPa.
- #1352387: MDM - Reset Filter => main UI goes into infinite loop.
- #1373741: MDM - Stress Properties - Delete revision - crashes when two revisions are identical.
- #1355758: MDM - General properties - Unit and year combo box values can not be changed.
- #1397040: Model Explorer - On first use, the models present in the selected folder appear in duplicate.
- #1327183: 2D Drawings - Program crashes when the legs are located on the bottom head.
- #1334644: 2D Drawings - Vessel on legs: when no cover plate is defined, drawing still shows a meaningless value.
- #1259796: 2D Drawings : Incorrect Distance Base Plate Edge to Web [EXV].
- Customizable Files
NOTE: Version 3.4- Config\flangeEN.emsd (Flanges EN 1092-1) (Updated)
- Config\up_apacadin.cel (DWG 2D drawings US units) (New)
- Config\up_apacadin.emsd (Keywords - DWG 2D drawings US units) (New)
- Config\up_apacadmm.cel (DWG 2D drawings SI units) (New)
- Config\up_apacadmm.emsd (Keywords - DWG 2D drawings SI units) (New)
- Security Release Notes
- CVE-2023-52425 and CVE-2023-52426 security vulnerabilities fixed.
[ Technology Preview]
Technology Previews provide users preliminary access to features currently in development and not QA certified and therefore not yet ready for production (please read carefully: EULA). These features are provided at no additional charge to promote awareness of a feature or technology to be deployed in a future release. Users are encouraged to provide feedback and suggestions. To learn more about Technology Previews or to gain access, please create a Service Request (be sure to include "Technology Preview" in the Description field).
