I have a question about the workflow of how Inroads is annotating horizontal alignments that are done for chord definition (rail). The issue we are seeing is the first couple of even hundred stationing ticks seem to not be exactly 100' when you measure the chord between them. If the curve is long enough that has multiple 100' tick marks then when you measure the chord 100'. This seems to be an issue at the PC and PT. Wasn't sure if Inroads is doing something different that we can't put our finger on.
OpenRoads | OpenSite Forum - Inroads Annotation of Chord Definition Alignments
