Not sure if this request should be in here or in the MicroStation forum, but I'm trying to convert approximately 2000 LAS files to POD format. Is there some sort of workflow that would speed this endeavor up or am I stuck being subjected to the constant dialogs for the convert settings and the POD file location for each LAS when the settings and the folder do not change?
ContextCapture | Descartes | Pointools | Orbit Forum - Convert multiple LAS to POD workflow
You can use the free Pointools PODcreator to convert point cloud files to POD format. In MicroStation > File > Point Clouds > File and select your LAS files. Are you wanting an automated way of converting your LAS files to POD?
