RAM | STAAD Forum - How to select plates and beams simultaneously using beam cursor , plate cursor each at a time?
Question
by
Bentley Communities Legacy Member
Expert
Created in RAM | STAAD Forum
I have created a model of 500 plates and 2000 beams. Some beams are connected to some plates. Let's say 200 beams are connected to 100 plates. Now, i want see only these 200 beams and 100 plates in 3D rendering view. To do that, we need to select only those 200 beams and 100 plates and need to click "view selected objects only" and then need to press " 3D rendering view". But the problem is I am not able to select both plates and beams together. When i select beams, I am not able select plates keeping the beams selected, and vice versa. Please help me if there is any technique to do so.
2 Replies ( Latest reply by
There is a cursor under "Select" called "Geometry Cursor", which would allow you to select beams and plates simultaneously.
thank you aswathi... im quite new to staad.. "learning by doing"
