RAM | STAAD Forum - Incorrect slenderness ratio for angle section
Question
by
Bentley Communities Legacy Member
Expert
Created (Edited ) in RAM | STAAD Forum
While designing the member using CAN/CSA S16-14 code. The slenderness ratio (KLR) parameter appears to be calculated incorrectly by STAAD. (refer attached snap)
The hand-calculated value comes out to be 1483/20.2 = 73.41 while STAAD reports 107.133. Consequently, the compression capacity appears to be underestimated by STAAD.
I am using version 20.07.11.45. Is this a bug?
Topics: STAADPro design
