[Archived] FileFormats Forum - Converting DWG Block attributes to DGN as tags in V8 and back to DWG
Question
by
Bentley Communities Legacy Member
Expert
Hello,
I saw the video on converting from DWG to Connect but i am curious if this is possible in V8.
OR how to go about accomplishing this. any resources would be most appreciated.
Thanks!
Accepted Solution
Open any file (DGN or DWG) then place the D-TBLK.dwg as a cell in that file (Element>Cells>File>Attach File). Once the D-TBLK is placed in the file as a cell, go to "edit tags" and select the cell. It should bring up the list you need to edit. The value column is what you want to change, NOT the name column.
