RAM | STAAD Forum - Modeling MCJs in Ram SS
Question
by
Sarah Twine
Created in RAM | STAAD Forum
When using RAM SS, should you use dummy members to model MCJs, or do you model the wall as continuous and then add the MCJs after importing the model into RAM Elements?
1 Replies ( Latest reply by
Sorry you lost me, what is an MCJ? Masonry Control Joints perhaps.  I think it makes sense to model walls as panels between control joints. Then you get separate shells in Ram Elements and you can then add gaps between them if you need to.
