MicroStation Blog - PokeIt for MicroStation — Select and View Elements Based on Attributes FROM Elements, Plus Much More
Blog
by
Tim Grimm
Contributor
Created (Edited ) in MicroStation Blog
PokeIt is a MicroStation VBA application. It's used to select, isolate or hide elements based on their attributes, such as level, color, line style, etc. The filter criterion is populated from a selected, or "poked," element rather than from a list in a dialog box.
PokeIt is also used to create elements similar to a selected element.
There are also a few additional “bonus” commands, Fit SelectionInvert Selection and Fence Subset.
The interface of PokeIt is a context menu, accessed with a right press and hold on an element..
See a demo of PokeIt on YouTube.
Attached is version 7.3 of PokeIt, and it's compatible with the MicroStation CONNECT Edition.
Note: Installation instructions are in the included PDF file.
  • PokeIt v7.3.zip 608.21K
