Enable "RealDWG 2016" Update for DWG 2015/2016 format in SS3/SS4
How to attach an ECW raster image to a DWG file within MicroStation?
OHM symbol in blocks in DWG is not displayed correctly in V8i
Open views do not retain open after closing and reopening DWG
Option Save relative path in MS XM when working with DWG is not available
Which MicroStation version supports which DWG/DXF version formats?
