(decibel) - A logarithmic unit of measurement that expresses the magnitude of a physical quantity (usually power or intensity) relative to a specified or implied reference level. The formula for decibel is: dB=10 log (P1/P2). In layman's terms, dB represents the difference in the intensity of an emitted signal or power where 0 dB is the reference, 3 dB is twice the intensity of 0 dB, 10 dB is 10 times the intensity, and 20 dB is 100 times the intensity and so on. (See also dBi, dBm and dBw.)
