SOILVISION CONNECT Edition Licenses
The following are descriptions of the various products available as part of SOILVISION CONNECT Edition:
SVSLOPE
The new standard in Slope Stability Analysis - users can perform classic limit equilibrium slope analysis of soil or rock slopes. Saturated and unsaturated analysis is possible. Steady-state and transient seepage pore-water pressures can be incorporated with SVFLUX.
SVDESIGNER
SVDESIGNER is a user-friendly 3D conceptual model builder used to significantly reduce model creation times by visualizing, optimizing, and merging engineering-staged construction/design, topology, borehole, piezometer/field instrumentation geotechnical data into a well-defined conceptual model for subsequent numerical modeling.
SVFLUX
Comprehensive 1D/ 2D/ 3D finite element analysis program designed to model groundwater seepage in unsaturated or saturated soils and rock for calculating steady-state and transient-state flow.
SVSOLID
1D/ 2D/ 3D finite element stress/deformation modeling for geotechnical earth structures involving elasto-plastic soft-soil behavior and consolidation as well as the elastic deformation of rock materials.
SVSOILS
Database of unsaturated and saturated soil and rock properties designed specifically for the estimation and mathematical representation of soil constitutive models for subsequent numerical modeling. Soil properties may be estimated by theoretical algorithms, data mining, and correlations.
SVENVIRO
1D/ 2D/ 3D finite element analysis software focused on environmental modeling, including coupled groundwater seepage, contaminant transport, freeze/thaw, and pore-air flow modeling. Software includes fully automatic mesh generation and mesh refinement. Rigorous calculation of actual evaporation by the Wilson method included. THA, TH, HA, and HC couplings possible.
SOILVISION SUITE
2D/3D SOILVISION Suite includes SVSLOPE, SVDESIGNER, SVFLUX, SVSOLID, and SVSOILS. SoilVision Suite enables you to reliably identify and analyze slope stability, flow, and environmental processes in hundreds of locations with one click with features like multi-plane analysis (MPA). You can also perform thousands of calculations with methods like probability and sensitivity. Start with extensive data import options to build comprehensive 3D digital designs and move through your workflow with multiple analysis methods, all done within SOILVISION’s interoperable applications. Discover how you can save time and money with unprecedented abilities to quickly and confidently create common or complex real-world 3D numerical models.
