How to Configure AutoCAD Mechanical 2012 to run as Vanilla AutoCAD with AutoPLANT SS4
 Product(s):AutoPLANT Piping
 Version(s):08.11.09.140
 Environment: N/A
 Area: AutoCAD
 Subarea: Profile
 Original Author:Justinas Lipnickas, Bentley Technical Support Group
AutoPLANT is not supported to run on top of AutoCAD Mechanical in a out-of-the-box installation. To run it with AutoCAD Mechanical, you need to configure it to run with a Vanilla AutoCAD profile, while working with AutoPLANT.
  1. Install AutoCAD Mechanical 2012 and AutoPLANT v8i SS4
  2. Launch AutoPLANT v8i
  3. In Tools->Options->Files remove the following support paths:
  4. Change the “Main Customization File” to acad.cuix, by default it is located at:
    C:\Users\<<User name>>\appdata\roaming\autodesk\autocad mechanical 2012\r18.2\enu\support
  5. The results should look something like this:
  6. Click OK, Restart AutoPLANT and it will load using Vanilla AutoCAD.
  7. Go to Tools->Options->Profiles, export AutoPLANT_PDW811ACAD_A005_409 profile, and import it to other computers if necessary.
[[Bentley AutoPLANT]]
