Changing ProductIDs - Impacts on SELECT contracts since CE and since Update 5
Changing ProductIDs between V8i and CONNECT Edition
Users of sisNET, sisFLOW or sisVIEW capabilities on V8i SS4 were using these capabilities as part of the OpenUtilities Designer, Map or PowerView products. Since the first release of sisNET CONNECT Edition (CE), we are switching from OpenUtilities Designer, Map and PowerView products to sisNET, sisFLOW and sisVIEW products. Users of sisIMS V8i also had Geo Web Publisher (GWP), Geo Web Solutions (GWS) and MicroStation for the sisIMS servers in their contract.
After upgrading to CE, many of these products are no longer needed. They are removed from the SELECT contract at the first renewal after a user has upgraded to CE. The impact on the contract price is minimal, if any, because desktop users did not have to pay separately for the OpenUtilities Designer, Map or PowerView licenses, and because the SELECT costs of the sisIMS-related products GWP, GWS and MicroStation are now included in the SELECT cost of sisIMS CE.
Bentley products are listed on SELECT contracts with a Material number and a Material Description. See the following table for an overview of the products that are no longer needed:
Product Name
ProductID
Material
2164
9422
Bentley OpenUtilities Designer SELECT Su
OpenUtilities Map
2418
11247
Bentley OpenUtilities Map SELECT Sub
OpenUtilities PowerView
2419
11243
Bentley OpenUtilities PowerView SELECT S
Geo Web Publisher
1189
11811, 11812, 11813 (for 10, 50, 100 users)
Geo Web Publisher (10, 50, 100) User SELECT Sub
Geo Web Solutions
1213
11908 (10 users)
Geo Web Solutions 10 Users SELECT Sub
MicroStation
1000
1003
MicroStation SELECT Subscription
Changing sisNET ProductIDs since CE Update 5
Since sisNET CE Update 5, we are transitioning to a new, single ProductID for all sisNET products. To replace the old sisNET Electric, Heat, Gas, Water, Wastewater and Multi Utility products and their ID's to the one new ProductID 3172, the following procedure is used:
For sisIMS, sisFLOW and sisVIEW, there are no changes in ProductIDs or Material numbers.
The following table lists the old sisNET ProductIDs and their SELECT Materials:
Product Name
Old ProductID
Old Material
Old Material Description
OpenUtilities sisNET Electric
1656
4343
D* Bentley OU sisNET Electric SELECT Sub
OpenUtilities sisNET Heat
1657
4351
D* Bentley OU sisNET Heat SELECT Sub
OpenUtilities sisNET Gas
1658
4356
D* Bentley OU sisNET Gas SELECT Sub
OpenUtilities sisNET Water
1659
4362
D* Bentley OU sisNET Water SELECT Sub
OpenUtilities sisNET Wastewater
1660
4367
D* Bentley OU sisNET Waste Water SELECT
OpenUtilities sisNET Multi Utility
1661
4346
D* Bentley OU sisNET M' Utility SELECT S
The next table lists the new sisNET ProductID and its new SELECT Materials:
Product Name
ProductID
Material
3172
15308
OpenUtilities sisNET Energy SELECT Sub
15311
OpenUtilities sisNET Water SELECT Sub
15314
OpenUtilities sisNET Multi SELECT Sub
As an example, if you had the following mix of old sisNET products in your contract:
then you will keep all these old licenses free of charge for 1 year, and get the following paid licenses added to your contract:
