What's new in 1.3.21
 Product(s):Assetwise ALIM Linear Referencing Services (AWLRS)
 Version(s):1.3.21
 Environment:N/A
 Area:N/A
 Subarea:N/A
This is maintenance version of AWLRS fixing several bugs raised by our users. It also includes bug fixes for  the Transportation Data Loader (TDL) module including TDL User Guide.
Log No. Summary
This section summarizes all major software issues that have been addressed by this release.
For issues raised by users, Bentley Technical Support Group (TSG) Ticket Numbers are cross referenced where applicable.
AWLRS
Cannot Create Roles in AWLRS as NON HIG_OWNER
739730
7001327075
Adding a WMS layer that only supports 1.3.0 fails
799001
WMS Background layers are not selectable
946497
7001445193
Network Edits - Start Date incorrect when edits are after 1600 hours PST
1037370
7001459950
[Datum Group] Cannot re-select flexible attribute after validation error
800003
[Asset Maintenance] Location tab should be enabled for off-network assets
763273
Reclassify Route forces unnecessary edits to activate Save Button
779432
7001356115
[Asset Maintenance] Populate with Current Route and MP when relocating
779423
7001356114
[Asset Maintenance] Display Issue with Hierarchical Assets
863704
7001398211
Foreign Key not auto populated in Hierarchical Asset Children
882747
7001411576
Asset Relocation Effective Date Resets
998535
7001482123
Copy / Trace Fails
1040387
7001424206
Graphic for new asset record not updating consistently
1083298
7001367112
Sort Columns Asset Maintenance Form
1099335
7001555226
Non EPSG projection shapefiles can not be loaded in AWLRS
1063299
Inconsistent Loop Rescale
1083282
7001495650
Line shape disappears while reshaping
1106198
7001561824
TDL
Various UI fixes to improve clarity and workflow
693344
Unable to Load Bar Delimited Files
867527, 1067299
7001530369, 7001398763, 7001530365
Submission Download Button Error
1072735
7001532139
Date fields in the Input file are not getting populated
1072739
7001532141
