Insitu Pocket Penetrometer and Hand Vane Readings by Elevation
Description
A scatter graph plot which shows the results from pocket penetrometer and hand vane tests performed in the field. In this example the results are plotted by elevation.
Instructions
To Load this report select the Load button from the "Reports Selection Window" within the Excel Extension and then select the file downloaded using the link below.
Download:
Please contact the support team and request for the 'HandVaneandPocketPenetrometerVsElevation.xlsm' file.
