iTwin Capture Modeler Flex & iTwin Capture Engine Licensing - Overview, Offering and Migration paths
iTwin Capture Modeler Flex, a powerful new application that brings simplicity, flexibility, and performance to your 3D modeling workflows.
One Application to Replace Them All
iTwin Capture Modeler Flex replaces all previous solutions, including:
With a single client application, you now have two ways to process your data:
And here’s the gamechanger: there are no more limitations on the number of engines you can run in parallel. Scale your processing power as needed.
A Smarter, More Flexible Offering
We’ve redesigned our offering to give you more control and value:
Offering
1. Virtuoso Subscriptions
Our new products are available on Bentley E-store (Virtuosity) under 2 new subscriptions:
This Virtuoso Subscriptions include a 12-month practitioner license of the associated software, and come with Keys (credits) to unlock training and services.
2. Perpetual licenses
iTwin Capture Engine can be purchased as perpetual licenses.
A perpetual license of Bentley software is a one-time purchase, with a yearly maintenance subscription, called SELECT. This includes 24/7/365 technical support, learning resources, and the ability to exchange licenses for other software once a year. With SELECT, you will benefit from:
If you want to know more about the pricing and conditions, please contact us.
3. Cloud subscription
Users can subscribe to our iTwin Capture cloud services to enable cloud processing capabilities. iTwin Capture Modeler Flex is our dedicated client application to prepare projects and submit processing locally or in the cloud.
iTwin Capture Cloud Services leverage the power of cloud computing to capture, manage, analyze, and share reality data to create–and continuously update–a digital twin of your infrastructure.
Comprehensive and cost-effective, this solution empowers reality data capture with the ability to provide field-based, insight-driven decisions through a 4D single source of truth. Make your data actionable so stakeholders can access the right information at the right time and make more informed, timely decisions throughout the project lifecycle.
iTwin Capture Cloud Services offer all the benefits associated with cloud technology–high scalability and accessibility from web, mobile, and desktop clients without new hardware purchases or maintenance costs.
Migration paths
Users with legacy Virtuosity Subscription for Reality Modeling WorkSuite can use iTwin Capture Engine and iTwin Capture Modeler Flex with their current subscription.
At renewal, users will be able to choose from the two new subscriptions from Bentley E-store (Virtuosity):
To ensure smooth migration to our new products, legacy products remain covered by those two new subscriptions. This includes:
All of the above products report usage under the iTwin Capture Engine license. iTwin Capture Modeler Flex client application is free of charge.
2. SELECT users
Users with perpetual licenses of legacy products that are covered by SELECT have automatic access to iTwin Capture Modeler Flex and iTwin Capture Engine products and updates.
To recognize the initial investment into our higher legacy product edition, iTwin Capture Modeler Center, a 2 for 1 policy is applied.
At SELECT renewal, all covered licenses will be renewed with the new iTwin Capture Engine and associated SELECT fee.
All the above products report usage under the iTwin Capture Engine license. iTwin Capture Modeler Flex client application is free of charge.
All this gives our Center users the great advantage that they automatically benefit from additional licenses as per the above, to cover for either the new products, or the legacy products usage.
3. E365
Starting April 1st 2026 the following lines are removed from the E365 pricebook:
This new line has been created:
 All iTwin Capture Modeler usage (legacy or new products) will be under the new iTwin Capture Engine.
Legacy products can still be used and remain available for download and use. iTwin Capture Modeler, iTwin Capture Modeler Center Master and iTwin Capture Center Engine are reporting usage under the new iTwin Capture Engine and are billed accordingly.
4. Legacy products support
iTwin Capture Modeler Flex and iTwin Capture Engine are the continuity of our Modeler Legacy products, therefore, there are no new releases expected for legacy products, including Modeler and Modeler Center that are being retired.
5. FAQ
1. The New Product Offering
Q: What is changing with the iTwin Capture products?
A: The iTwin Capture Modeler Desktop and iTwin Capture Modeler Center products are being consolidated into a single new offering called iTwin Capture Engine. This new product requires a free prerequisite, iTwin Capture Modeler Flex.
Q: What is iTwin Capture Modeler Flex and how do I get it?
A: iTwin Capture Modeler Flex is a new, free product that is required to use the iTwin Capture Engine. It can be downloaded from the Bentley Software Downloads portal using a Bentley IMS account.
2. Licensing & Pricing
Q: How do existing SELECT subscribers get the new product?
A: Accounts with active SELECT subscriptions automatically received entitlements for the new iTwin Capture Engine without needing to make any payment.
Q: What is the annual cost for the new iTwin Capture Engine?
A: Upon renewal, licenses for the old products will be migrated to iTwin Capture Engine at the new SELECT subscription per license, per year.
Q: How is software usage counted if I use both the old and new products?
A: If you hold a license for iTwin Capture Engine, any usage of either the old products or the new product by a single user on a single machine will be counted as one license use.
3. Migration & Transition
Q: Will I lose access to the old iTwin Capture Modeler after my subscription is renewed to the new Engine?
A: No. After renewing to iTwin Capture Engine, you will continue to have access to download and use the legacy products. This is to ensure you can continue working on ongoing projects. This holds true even for multi-year contracts.
Q: Will the old products receive future updates?
A: No. While the legacy products will remain available for download, there will be no future software releases or patches for them.
Q: What happens to existing contracts?
A: Existing contracts for the retired products will be migrated to the new iTwin Capture Engine at renewal. The new product will become billable on your contract's next renewal date.
Q: I am using iTwin Capture Console to submit processing jobs to the Reality Modeling Cloud Service. What happens to my cloud subscription and access to iTwin Capture Console ?
A: Reality Modeling Cloud Service subscription remains unchanged. However, iTwin Capture Console is being retired. Instead, we recommend our users to move to the free iTwin Capture Modeler Flex client, to create and manage their projects and submit processing to the cloud.
4. Product Compatibility & Usage
Q: Can I open my old projects in the new iTwin Capture Modeler Flex?
A: No. Projects created with the legacy iTwin Capture Modeler or Center products are not compatible with the new iTwin Capture Modeler Flex, and you cannot open or import them into the new software.
Q: How should I manage my projects during this transition?
A: You should continue using the legacy product version for any existing or ongoing projects. New projects should be started using the new iTwin Capture Engine and Flex products.
5. Availability & Timelines
Q: When did these product changes take effect?
A: The consolidation and repackaging were effective from March, 2026, with the new products becoming commercially available that same week.
Q: When do renewals from iTwin Capture Center to iTwin Capture Engine begin?
A: The process for renewing iTwin Capture Center contracts into iTwin Capture Engine is scheduled to begin on July 1, 2026.
Q: When will stop the support of the old products?
A: Legacy products will remain supported through May 4, 2027, allowing ample time for transition.
