Spiral Type - Design File Settings vs Reports vs XML
This is mainly to understand why, sometimes, you get "spiral unknown" when importing from LandXML.
It often happens when importing cubic or cubicParabola.
We have many cubics in OpenRail Designer.
You must know which one to use. Set Design File Settings>Civil Formatting accordingly before importing: the unknown spiral will be replaced by the one from Design File Settings. Or find/replace the spiral type in the XML file with the name you will find in the XML column below.
Design File Settings Reports XML
Clothoid Clothoid Clothoid
Biquadratic Parabola Biquad. Parabola Biquadratic
Bloss Bloss Bloss
Sinusoid Sinusoid Sinusoid
Cosine Cosine Cosine
NSW Cubic parabola NSW Cubic parabola NSWCubic
WA Cubic parabola WA Cubic parabola WACubic
MX Cubic parabola MX Cubic parabola MXCubic
Chinese Cubic Parabola Chinese Cubic Parabola CNCubic
Italian Cubic Parabola Italian Cubic Parabola ITCubic
Sine Half-WaveLength (Japanese Sine) Sine Half-WaveLength (Japanese Sine) HalfCosine
Czech Czech Cubic Parabola CZCubic
Arema Arema Cubic Parabola AREMACubic
Polish Cubic parabola Polish Cubic parabola POCubic
XML definition
enumeration  biquadratic
enumeration  bloss
enumeration  clothoid
enumeration  cosine
enumeration  cubic
enumeration  sinusoid
enumeration  revBiquadratic
enumeration  revBloss
enumeration  revCosine
enumeration  revSinusoid
enumeration  sineHalfWave
enumeration  biquadraticParabola
enumeration  cubicParabola
enumeration  japaneseCubic
enumeration  radioid
enumeration  weinerBogen
