In the table below you can find an overview of all webinars and trainings that are available on-demand organized by engineering application.
Click on any category below to focus on the subject you are interested in and click on any title to visit the registration page.
For onboarding training paths, see the related page on Online Learning - GeoStudio.
| Foundations - Piles - Reinforcements | Product | Level | Type | Date |
| Stability of a Mechnically Stabilized Earth Wall | ** | Tech Talk | May 2022 |
| Dams - Embankments | Product | Level | Type | Date |
| Practical Guide to Dam Stability Investigations using GeoStudio | * | Coffee Corner | March 2026 | |
| From Theory to Practice: FEM and LEM in Rock Slope Stabilisation | * | Coffee Corner | September 2024 | |
| Combining a PLAXIS analysis with SLOPE/W's Limit Equilibrium for slope stability | * | Coffee Corner | October 2022 |
| Tunnels | Product | Level | Type | Date |
| Tips for Modelling Tunnel-Pipes | * | Answer Hour | August 2025 |
| Seismic - Dynamics | Product | Level | Type | Date |
| Tips for Dynamic Stability Analysis | ** | Answer Hour | January 2025 |
| Groundwater Seepage - Pore Water Pressures | Product | Level | Type | Date |
| Using laboratory and climate data to inform complex seepage analysis in GeoStudio | * | Coffee Corner | June 2026 | |
| Tips for Defining Water Pore Pressure in LE and FE analysis | * | Answer Hour | February 2026 | |
| SEEP/W: Interrogating Seepage Results and Dealing with Convergence Issues | * | Tech Talk | September 2022 | |
| Land Climate Interaction Analysis with SEEP/W | * | Tech Talk | May 2020 | |
| Establishing Appropriate Column Grids and Meshes for 3D LE and FE Analyses | ** | Answer Hour | November 2025 | |
| Groundwater Flow in Shaft and Tunnerl Design | ** | Tech Talk | April 2022 | |
| Groundwater Dewatering and Drawdown Maps in SEEP3D | ** | Tech Talk | April 2021 |
| Heat Transfer | Product | Level | Type | Date |
| Mastering 3D Analyses: Heat Transfer in Complex Geology (Part 2) | ** | Tech Talk | February 2023 | |
| Mastering 3D Analyses: Heat Transfer in Complex Geology (Part 1) | ** | Tech Talk | January 2023 | |
| Surface Energy Balance in TEMP/W | ** | Tech Talk | April 2020 |
| Rock Mechanics | Product | Level | Type | Date |
| Mastering SLOPE3D: Structurally Controlled Stability Analysis of an Open Pit | * | Tech Talk | September 2025 | |
| API and Python scripting | Product | Level | Type | Date |
| Streamlining Geotechnical Workflows with API Scripting in GeoStudio 2025.2 | ** | Coffee Corner | December 2025 |
