Meter
Widget size: 1 x 1
This widget shows the latest value for a given point on a meter graphic. Clicking on the graphic drills down to an Analytical Viewer of the previous meter readings.
This widget is site specific.
The parameter can display any value or measurement.
Customisation
Value Default Comment
Widget Heading Meter Widget Enter the name of the widget as it is to appear in the heading.
Meter colour Grey Select from one of grey, blue, green, light blue, orange or purple from the drop down list.
No. of Decimal Places 0 Select the number of decimal places to be displayed for the reading
Meter Details Label Display Details label Display the meter details label - Yes or No
Timestamp On? 0 Display the timestamp - Yes or No
Drill down engineeringChart.jsp The default drilldown is to the Analytical Viewer, but an alternative can be specified. Specify the Comparison Chart URL (comparisonChart.jsp) or the Single Charts URL (multipleCharts.jsp)
Alternative units text No default set Enter alternative text for the displayed units.
Display full path No Display the full path under the meter details - Yes or No
Scrollable No Select if you want to be able to scroll back through different periods.
Scroll Period Year Select monthly or yearly to scroll back.
Start Month (for year scroll period) January Select month to start. This ONLY applies if Yearly is selected above.
All Sites No No - The data is dependent upon the site selection from the dashboard navigation treeview. Yes - Data is displayed regardless of treeview selection.
Refresh Period No widget refresh Select a refresh period from the drop down menu from between 15 seconds to 1 hour, or no refresh at all
Point 1 Heading [point name] Overwrite the original point name with something else.
Properties
Drag and drop the required point(s) for the meter from the tree.
