Autodesk Revit Plugin
Export To LumenRT - With the 3D default view displayed, go to the Revit Add-Ins tab and click the LumenRT Export button. This will initiate an immediate export of everything visible in the scene including model elements, LumenRT proxy content and lights.
Adding LumenRT Immersive Nature Content
Revit does not support external 3D content libraries. Therefore, to add Immersive Nature content such as plants, characters, vehicles, use the LumenRT LiveCube editor to add these items directly.
Exporting Lights - In Revit, lights are added to the scene using the standard Revit lighting fixtures and objects and then assigned to a lighting group. All lights must be assigned to the light group to properly export the lights into LumenRT. Begin by adding a Revit light to the scene and then assign it to a light group as shown below
