Month Overview
Month Overview
Month Overview reporting tool displays the average values of a sensor readings for each hour of every day for all the days of a month. User selects the sensor using the Station and Variable selections, and the month and year of the data to be reported.
The total average, maximum and minimum is calculated for each day of the month. Also, the total average, maximum and minimum is calculated for, each hour and also for the total number of values.
At the very bottom of the report there is information of the total hours of the month, the number of good hours (hours with data), the number of missing hours (the hours with no data) and the data capture in percentage.
  1. Select Station, Variable, Year, and Month
  2. Download the data to a text file
