Applies To | |||
Product(s): | AutoPIPE Vessel | ||
Version(s): | CONNECT Edition | ||
Environment: | N/A | ||
Area: | Modeling | ||
Subarea: | |||
Original Author: | Bentley Technical Support Group | ||
Date Logged & Current Version | Apr. 2016 40.01.00.09 | ||
Problem:
Need to add 10 vents of 2" in the below vessel component but the application only let me add 4. How can I add more Vents?
Answer:
Only 4 vents are allowed into the skirt. I assume that a workaround for these 10 holes into the skirt is to simulate the same opening wide with 4 holes of 5". It's just a suggestion I don't know if it works. AutoPIPE Vessel checks the minimal actual section in a plan considering holes to perform the calculation of the skirt.
