Applies To | |||
Product(s): | InRoads | ||
Version(s): | 08.11.07.615 | ||
Environment: | N/A | ||
Area: | Roadway Designer | ||
Subarea: | |||
Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
My design surface goes beyond desired limits, how can I prevent this?
Within Roadway Designer>Manage Corridor if you do not select Station Limits, the corridor is processed based on the entire length of your alignment. You can indicate your desired limits by selecting Station (Limits) and keying in or selecting your desired station limits with the pick button. If you are changing your existing corridor limits, ensure you select Change for this modification to take effect.
