| Version: | 08.05.01.25 | ||
| Area: | DGN | ||
| Subarea: | General |
When referencing a drawing in a DWG file, there is a way to select a specific level for the Viewport. Is there a way to do the same thing in a DGN file.
1. Open the workmode.cfg file, by default located in the ..\bentley\program\microstation\config\system folder in any text editor (such as Notepad).
2. Add the following to lines to this file: _USTN_CAPABILITY_DGN < +CAPABILITY_REFERENCE_ATTACHLEVEL
_USTN_CAPABILITY_DGN < +CAPABILITY_REFERENCE_VIEWLEVELDISPLAY
This should allow the same Viewport level capabilities while in a DGN file.
